09-24-2015 12:43 AM
Pixma. Getting message Paper jammed, but there is no paper in printer. How to resolve
05-21-2020 11:57 AM
I have the same issue of papaer jam error with no papaer in the printer. I went through the recommeneded steps just to be sure, 100% certain no paper jammed, but sll get the error. appreciate any advice.
05-21-2020 12:01 PM
Thank you for your inquiry, and welcome to the Canon Forums.
We appreciate your participation, however, for the community to best assist you can you provide us with the model name of your printer?
If you live outside the United States, please visit: https://global.canon and select your country or region for your support needs.
05-22-2020 02:03 PM
My Cannon Pixma is a MG3520
It still has an error for a paper jam even though there is no paper in he printer.
07-27-2020 01:34 PM
08-07-2020 09:03 AM
Since there is no paper jam, I recommend performing a reset of the printer. While the printer is on, unplug the power cord from the printer and let it sit for 60 seconds. While the power is off, press the power button 5 times. After 60 seconds plug the power cord back in and power on the printer.
If that does not resolve your issue, contact Canon at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST.
08-08-2020 04:16 PM
08-12-2020 06:23 PM - edited 08-12-2020 06:25 PM
Hi loriand
If the steps provided didn't correct the problems, then if you're located in the U.S., contact Canon at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST. If you have not yet done so, you may first need to register the printer at https://mycanon.usa.canon.com/
If you're located outside of the U.S., you may find your regional branch of Canon through the map at https://global.canon/en/support
07-28-2020 03:09 PM
