Pixma MX922 not recognized by Dell laptop any longer
Taylortori
My Pixma MX922 not recognized by my Dell laptop any longer.  It was printing fine until yesterday. I've deleted and attempted to re-add, but it's not found while sitting right next to the printer.  When I was able to add it yesterday, it would show "ERROR" as the status on my laptop.  I'm able to print from mobile phone and desktop.  Please advise.
5 REPLIES 5
Moderator
Moderator
Hi, Taylortori!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Windows 11 Home
Patrick
Hi Taylortori,
Please follow these steps:
1.  Please press the MENU button on your PIXMA MX922
2.  Use the down arrow to select the wrench and screwdriver icon and press OK
3.  Use the left arrow to select Device Settings and press OK
4.  Use the down arrow to select LAN settings and press OK
5.  Use the down arrow to select Confirm LAN settings and press OK
6.  Select WLAN setting list and press OK
Please verify that the name listed next to SSID is the exact same name your laptop is connected to
Using the down arrow, write down what is listed next to IPv4 Address.
On your computer, please press the Windows key on your keyboard and the letter R, then let both go
In the Run window that appears, please type CMD and click OK
In the Command Prompt window that appears, please type:
PING (IP address that you wrote down)
and then press the Enter key on your keyboard
For example, if you wrote down 192.168.1.45, type PING 192.168.1.45 in the Command Prompt window and press Enter
Did you get:
A - Timed out
B - Destination host unreachable
C - Sent = 4, Received = 4, Lost = 0
I received sent=4 received =4 lost=0
What do I do now?
Please open a web browser on your computer, and in the address bar, please type the IP Address on the configuration page into the address bar. Next, tap Go or Enter to access the page. Are you able to see the printer's remote interface?
