05-31-2022 11:05 PM
My Canon MG7520 was working perfectly until yesterday. It kept shutting itself off yesterday. Today it would start the process of turning on, but turn off before it would get to the menu. I know it's getting older, but it's worked so well until now. Is there anything I can do?
06-02-2022 11:22 AM
I literally unplugged my router and wifi boxes out of the wall and then turned my printer on and reset it then plugged my router and wifi boxes back in.
06-02-2022 01:54 PM
I did this work around today, I turned my wifi off, disabled LAN, and now my MG 6620 printer turns on and stays on. But I’ll have to clear space on the desk so we can hook it up to the computer to use it
06-02-2022 03:10 PM
Same problem. Went to use my 7520 this morning and it was off. I NEVER turn it off. It only comes on for 5 seconds and shuts off. The ink cartridges do not slide. The door opens and it shuts off. I used it May 31 and had no problems.
06-02-2022 05:48 PM
Wow. What is going on. I am going through the same issue as everyone who's previously commented about their MG7520. I used my MG 7520 just two days ago and for the past 30 minutes, the printer was found off, turns on then turns off, says is offline, and only stays on for no more than 1 minute when I am attempting to do anything to it.
06-02-2022
07:35 PM
10:24 PM
SamanthaW
SOLUTION: After a 1:57 hold time with Canon customer service.... I have the solution! (and that was 2 hours, not 2 minutes) If this is happening to you it is very easily fixed. [Removed per forum guidelines] Although I wish I could make up for my 2 + hours of time. The tech told me that when they walked into the office Tuesday morning, "the stuff had hit the fan" because this has affected many models and they don't know what caused it. Here is what you need to do to fix it:
Completely unplug your router and then turn on your printer (it won't stay on if your router is because of a linking problem with the router, that we are going to fix.) So this is the step-by-step for the MG6620 and probably those models with similar menus, but whatever model you have just try to get to your DNS Server Setup. That is where the setting is that needs manually changed. So for the MG6620:
On the menu swipe to Setup, then find Web Service Setup then DNS Server Setup. Select Manual. Press each set of numbers and change them all to 000 except the last set. That needs to be 001. So your DNS will look like this: 000.000.000.001 Click OK, then click No.
That's it. You should be good to print.
You are welcome! Too bad someone at Canon doesn't just post this somewhere. Would've save a lot of people a lot of headaches, I'm sure.
06-02-2022 07:46 PM - edited 06-02-2022 07:56 PM
@leafstar You may want to update this with a fix update that Sheri99 just posted! That way everyone can see it since I don’t think anyone is reading all the comments.
06-02-2022 07:52 PM
Thank you for taking one for the team. This fix worked!
06-02-2022 08:27 PM
Ok. (I am still laughing-hang on) You are an angel! Your message to me arrived moments before I dropped an 8 pound sledge hammer on my printer. I had just purchased 120 dollars worth of Canon pure-bread ink a few days ago for this thing. I printed a few pages on 5-30-2022 and was stunned that today it was DOA. I started reading your message and got to the pay me in VenMo and my blood boiled. I thought Gee, I was right it was a Russian Hack! And.. me, bent on discovering who you were and why you would perpetrate such a dastardly attack on my right to print nonsense and cat memes! I carried on reading to discover the VenMo was a joke. Wiping the sweat from my brow I hungrily chewed through the rest of your message, relishing every word until satiated. I followed your instructions as if I was a 3 year old learning the most important thing in my life! I proceeded to diligently carry out your instructions, blindly, without questioning the knowledge and precise steps. I took those steps unerringly, unfaltering, my first steps to everything. Besides if I fell I had already forgotten about the boo-boo, I will survive, my will enslaved me, I would not be denied. It worked perfectly! I cannot thank you enough. I am sure canon doesn't post the solution because they want that 20 dollars from all the people with Out of Warranty printers. That could back fire by not selling printers to customers, then what do they have?
Your reward for your informative message to me is, sleep well Sheri99, you wear a golden halo and are cloaked in gossamer wings in my eyes. Thank you for your timely informative assistance. You saved me in more ways than one, and you saved my printer from a unrecoverable fall down a 5 story staircase. My printer thanks you and I thank you.
06-02-2022 08:35 PM
Scroll down and Read sheri99s message. \/ down there!
06-02-2022 08:36 PM
Scroll down and read sheri99s message.
