PIXMA iX6520 Skips Lines
jbfrommv
I have a PIXMA iX6520 printer. I was cleaning the bottom plate when the paper jammed. After removing the paper, the printer stopped printing a line every 1 and 1/2 inches. I thought the print head might have been damaged during the paper removal process and replaced it. That did not solve the problem. The problem occurs when printing in the standard mode, but not when printing pictures. The computers that use this printer are running Windows 7 and Windows 10.
3 REPLIES 3
Perform a print head alighnment.
Also look at and clean the Encoder (Timing) Strip.
https://support.usa.canon.com/kb/index?page=content&id=ART171023
Performed the printer head alignment, and cleaned the encoder strip.  Did not solve the problem.  The problem occurred after attempting to clean the bottom plate.  The paper jammed and I suspect that a piece of the paper still in the printer is causing the problem.  The skipped printing occurs at regular intervals in the lines of print.
flj0303
I have this same problem on a Pixma TS 8220 printer. I've tried everything, cleaning encoder strip, print head alignment, etc. Nothing worked. Did you ever solve this problem.? I gave up and bought a new Epson printer out of disgust, but still have the other one and would love to "rehabilitate" it if possible.
Would love to know if you found the fix..
