07-18-2018 04:21 AM
I just bought a PIXMA iP8720.
Some of the colors are way off.
RGB color (0,255,0) should be bright green, but it prints much darker. Closer to (0,100,0).
When I print a darker green (0,128,0) it also looks like (0,100,0)
Light blue (0,255,255) is also much darker.
Yellows are pretty close. Browns and grays print lighter.
The colors look correct in the print preview. I've adjusted my monitor, etc.
I've read forum pages and Google results for hours.
I've tried changing most settings one by one and get the same results.
Any help is appreciated.
07-18-2018 10:51 AM
This is almost always an issue with workflow. Or using one or more programs in that flow that applies one or more ICC Profiles and double processes your output. Monitor calibration software if used, can also affect output.
Provide your complete workflow... start to finish. From import to output. The software you use, anything that a photo passes through and we can likely help you figure out whats happening.
07-18-2018 12:37 PM
shadowsports, thanks for your time.
If I go to https://www.colorcombos.com/images/colors/00FF00.png and try to print that green box straight from the website, these are the results.
The color on the left is the color on my screen. The color on the right is what it prints.
07-18-2018 02:09 PM
The difference is huge, it's hard to use a printer like that. Since you've just bought it, I think you can still return for technical check and still covered by warranty.
07-18-2018 06:17 PM
I installed Illustrator.
I draw a rectangle the same color as above and get the same result as above.
07-20-2018 10:12 AM
If you still believe the printer is defective, exchange it. If it happens again, you will know its color profiles in your workflow.
