05-04-2025
11:33 AM
11:53 AM
James_C
When I choose double-sided it says to indicate when to print the secod page, but when I do, it prints the 2nd side on another sheet of paper.
05-06-2025 09:06 AM
Thanks for joining the conversation, karencohen!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TS9500 series. The model number should appear at the bottom right corner of the printer's movable control panel. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
05-06-2025 09:30 AM
Sounds like you are printing manually. If so, are you reloading the page as discussed in the manual?
05-06-2025 11:24 PM
The printer can auto-duplex, or you can duplex manually. In Manual, it prints the first side, you flip the paper over, and tell it to do the second side. If you tell it to print the second side before you put the sheets back in, it'll print on the blank paper.
Read page 299 in the Manual:
https://downloads.canon.com/hsg2023/ijprinters/manuals/TS9500ser_OnlineManual_Win_EN_V02.pdf
