05-26-2026
06:34 PM
11:54 PM
Tiffany
Pixma TS7720 won't print from desktop. Never had problem before. The desktop says that the computer is on-line and the print dialog box appears. Also, scanning function works. I can print docs using laptop, so it doesn't appear to be a printer problem.
06-02-2026 12:44 AM
What is the IP address of your printer?
What is the IP address of your computer?
Can you ping the printer's IP address from a command prompt. Does it reply?
If you open a browser and enter the printers IP, then press enter, does it's webserver display?
Next steps can be provided when you reply..
06-02-2026 08:41 AM - edited 06-02-2026 08:42 AM
I know from much experience as a retired computer and computer networking tech that the best troubleshooting tool for an issue like this is a printer cable, it helps to narrow down the source. it will tell you right away if your wifi is the source if you can print using a cable and you can always go back to wifi once the problem with it is resolved. If you have to move a device closer to the other one, it is a temporary inconvenience to help solve a very inconvenient problem.
06-09-2026 04:00 PM
I was able to perform a nozzle check. Print function from desktop still does not work. Desktop scan function works, but scanned doc won't print. Print function from laptop, also WiFi connected, works fine.
