12-14-2025
04:47 PM
09:27 AM
Hello:
I have a computer specifically used to run AutoCad. It has no internet connectivity, running Win 7 x64. I have copied the mas2-win-104_0_0-ea34_2.exe, extracted all files within and ran .msi. I am trying to install software for TS7720.
When I finally got the installer to run, it fails because I have no internet, which is why I went to all this trouble in the first place. I really need to print an autocad drawing sooooo.....
PLEASE HELP
thank you so much
12-14-2025 06:26 PM
Took some doing but it worked once I changed the port setting. Thanks so much!
BTW...why isn't this installer listed on Canon's website (or maybe it is & I just didn't see it)?
Thanks again
12-14-2025 04:59 PM - edited 12-14-2025 05:00 PM
I suggest using a usb cable to connect your printer, since you downloaded the software just run the program you copied over, do not connect the printer until asked to do so by the program. :
To install the Canon PIXMA TS7720 using a USB cable without internet access, connect the printer directly to your computer with the USB cable. Then, use the Canon Print app to complete the installation process.
Apple
ij.manual.canon
Connect the Printer:
Power On the Printer:
Install Drivers:
Add Printer on Mac:
Test the Connection:
By following these steps, you should be able to install and use your Canon PIXMA TS7720 printer without needing an internet connection.
12-14-2025 05:09 PM
Printer is plugged in, ran master setup, clicked "start setup" and get....
Download Failed
Check your current network connection, and then try again
12-14-2025 05:23 PM - edited 12-14-2025 05:26 PM
Please start here.
Disconnect the USB cable from your computer.
Remove the printer from printers and scanners if an instance is present. In Windows 7, you can get there by visiting the control panel.
Next visit Control Panel > Programs and Features and uninstall the driver that you ran.
Now restart your system.
Please download this installer instead of the master setup utility.
If this download is a self-extracting zip, rename the file extension from exe to.zip. I'm on a mobile device so I can't check this for you at the moment.
Once the file extension has been changed, right click on it and select extract.
Note, file extensions are set hidden by default in Windows 7, so you may need to use the View menu in Windows explorer and enable the checkbox show file extensions to see the extension.
Once the .zip file has been extracted, open and run setup. Look closely at the page that displays there might be a check box down at the bottom that says you don't have an internet connection. Make sure you click that before pressing next or OK.
Do not connect the printer until prompted to do so by the installer.
I will verify the steps above when I am back home.
Let us know if this helps. 😉
12-14-2025 06:26 PM
Thanks again
