PIXMA TS6420a won't save scan
aysrick
I have been really happy with the TS6400, but now I have a problem and can't figure it out.
The scan function just stopped saving images. It literally stopped doing so in the middle of a project. A previous scan saved, but now nothing will save after being scanned.
I deleted the scan software and resinstalled it. Did the same with the the drivers. But no luck.
8 REPLIES 8
Moderator
Moderator
Thanks for joining the conversation, aysrick!
So that the Community can help you better, please let us know which printer in the PIXMA TS6400 series you're using.  We also need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof) and which application you're scanning with. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Thanks. It looks like it is the Canon TS6400a.
I'm running Windows 10 Pro.
As I said, it was weird, because it just suddenly stopped saving and I hadn't had a problem up until that point.
I wanted to follow-up on this problem to see if anyone has a solution, since my scanner still isn't allowing me to save images.
Are you scanning directly from the printer or using IJ Scan Utility on the computer?
I'm scanning from the utility. As I mentioned originally, it's weird because it was working just fine and scans were saving without a problem. And then it wouldn't. I can scan and edit the image, but it won't save.
mgtaylor
What no answer to this problem! I'm having the same trouble, scans great but it will not save. I'm running Win 10 and scanning the IJ Scan Utility. It was scanning just fine then it quit saving. I've got a lot of stuff to scan yet.
Hi mgtaylor,
Please follow these steps:
1.  Right click your desktop, point to New and then click on Folder.
2.  Give the new folder the name New Scans.
3.  Please open the IJ Scan Utility.  To do this, please click on the Windows button at the bottom of your screen and scroll down to the Canon Utilities folder.  The IJ Scan Utility is in that folder.
4.  Once open, please click on the Settings button in the lower right corner.
5.  Click on Photo Scan on the left side.
6.  On the right side, in the Save Settings section, click the Save In drop down box and (go to next step)
7.  Click Add.. from the bottom of the drop down list.
8.  Click the Add button.
9.  Click on Desktop at the top of the list, click on New Scans and then click OK.
10.  Back in the Select Destination Folder window, select the New Scans folder and click OK.
11.  Please make sure that New Scans is now selected in the Save In box and then click OK.
12.  Back in the IJ Scan Utility, click the Photo button.
13.  Scanning will commence.  Once complete, please open the New Scans folder on your desktop.
Does the image that you just scanned appear in the New Scans folder?
Hi aysrick,
6.  On the right side, in the Save Settings section, click the Save In drop down box and ... (go to next step)
Did this answer your question? If so, please click the Accept as Solution button below so that others may find the answer as well.
