12-08-2017 08:02 AM
I get the message:
"Support Code 1000
There is no paper in the rear tray.
Check the following, than load paper and select (OK).
-Align paper guides with the paper.
How to clear OK"
I don't want to print from the rear tray; I want to print from the cassette tray. I do select the cassette paper type yet the message, above, is always the same. Support Code 1000 just tell how to load the cassette tray.
HELP, please
Dave5
03-22-2024 02:04 PM
My MG5300 has inexplicably switched to the rear tray occasionally. I just printed a 14 page doc from Google Drive on Chrome. Not certain which tray it was using this time but after 3 pages it gave me an error that the rear tray didn't have paper. It did. I fiddled with it and restarted the job a bunch of times. I found the Feed setting in Setup and made certain that it was on Cassette. The Printer settings for the job does not have any options about the Feed. I also turned the printer off and on. Nothing works. Help.
04-02-2020 10:53 PM
I have the same issue - it has all of a sudden decided that i should print from rear and not from cassette. I am considering throwing this printer against the wall to see it will reset. I have looked at online manual and elsewhere on the web and I cannot see how i can reset this so that it accepts the paper from the cassette.
I had another printer for years and replaced it with one. It only started giving me problems within a few months!!
If anyone has any ideas of how to reset the paper tray, let me know. I turned off and unplugged printer for a few minutes hoping that would reset it but it did not.
Thanks
04-16-2020 12:17 PM
did you find a resolution for this? I'm not having any luck with the suggestions listed
04-16-2020 12:34 PM
GAVE UP
04-16-2020 12:38 PM
thanks, glad Canon provided us with pieces of crap printers with forced top load paper entry and a fancy cartridge to STORE paper, but clearly not to feed from.
04-17-2020 12:44 PM - edited 04-19-2020 04:51 PM
Now, all 5 Canon TS8220 printers are ALL started every morning default source print from back tray. We have to feed paper one page at a time. The TS8220 will NOT print from cassette tray.
Then, we found out this Canon TS8220 printer had this exact unable to print from bottom cassette tray problem since 2013. That is SEVEN years since this problem has been shown in Google search. Canon has done NOTHING to correct this problem.
This makes us MAD. VERY MAD.
No response what so ever from CANON since 2013.
04-22-2020 11:45 AM
Found my solution here. Printing from Adobe was fine, my problem started with Word. See:
04-22-2020 11:52 AM
I'll save this for when I next print, thanks for sharing!!
04-23-2020 03:20 PM
In the PC printer controll panel, we have set the paper source from bottom paper cassette tray.
However, checking the printer, there are NO paper source setting. It default auto set the paper source from back tray.
This printer ignor the PC printer control setting.
11-02-2020 10:17 AM
@flstfhd07 wrote:Found my solution here. Printing from Adobe was fine, my problem started with Word. See:
