12-05-2023
01:54 PM
09:30 AM
Hello. I have a Pixma TS 6020 that was purchased in 2017. It is a combination printer and scanner. All features were functioning until recently. I am running a Mac with OS Sonoma 14.1.2.. I am currently still able to print, however, I am getting error readings when I try to scan. I re-dowloaded the driver but it still doesn't scan. Any help would be greatly appreciated.
01-09-2024 09:28 AM
welp. that link was broken. I fixed it.
It will look like this:
01-09-2024 10:27 AM
HI Stephen... I followed your instructions but am still having some issues.... When I try to scan a document, it does seem to scan it, but when I exit, I get a different internal error now...it tells me to "check scanner status, restart scanner, restart computer, reinstall scanner driver.... code 10, 202, 3".... I did all of the above but still get that error.... However, if I scan using the driver, it does scan, but not as a document saving as a pdf, but as a photo saved as a jpeg. Which is fine if I want to scan a photo, but not when I need to scan a document as a pdf... I can't figure this out! Any other suggestions? And thank you all for trying to help me!
01-16-2024 12:58 PM
Please follow these steps:
1. Click on the Apple in the upper left corner.
2. Click on System Preferences.
3. Click on Printers & Scanners.
4. Click once on the Canon TS6020 and then click the [-] at the bottom to remove it.
5. Once gone, click the [+] and then click Add.
6. When the Canon TS6000 series appears, click on it one time.
7. At the bottom, next to "Use", select the Canon TS6000 series (not Airprint or Secure Airprint).
8. Click Add
Once the printer is readded, please restart your computer and then open IJ Scan Utility and try to scan again.
01-16-2024 02:01 PM
Hi again... Sorry this is so frustrating. I followed all of your instructions but I am getting the same error code again: 10, 202, 3.... When I check the scanner in IJ Utility it is listed as TS 6000 series, and not the 6300, even after I downloaded the driver 5.0.0 again. This might be beyond what I am capable of!!! I do greatly appreciate all of your assistance and not sure what else I can do.
