01-03-2020
07:08 AM
10:19 AM
When printing from the front cassette, the paper will come out the rear of the printer and will then display a no paper message. If I print from the rear tray it prints fine.
01-03-2020 10:42 AM
The typical cause for this behavior is the default paper tray setting in the printer driver or properties.
You may have the default tray set for the rear.
10-23-2023 03:25 PM
Hello..I went into feed settings and changed from rear cassette to front cassette. Tapped 'register' and when I exited, the settings defaults back to rear. any suggestions
10-23-2023 03:33 PM
What device are you printing from? Are you using the Canon Print app, or AirPrint?
