PIXMA TS3722 Error code E03
Abaker922
I have the Pixma TS3722. I tried to print an important document for my business and I keep getting an E03 paper jam code. Every time I try to print, the printer takes in about half the paper and makes a loud noise and stops feeding the paper. I have followed all the steps on cleaning out the printer and nothing still seems to work
1 REPLY 1
DerrickL
I suspect you have already taken most of this steps:
Troubleshooting Steps
To resolve the E03 error and the accompanying loud noise, follow these steps:
  1. Check for Paper Jams
    • Open the printer cover and inspect for any jammed paper.
    • Remove any stuck paper carefully to avoid tearing.
  2. Ensure Proper Paper Loading
    • Verify that the paper is loaded correctly in the tray.
    • Make sure the paper guides are snug against the paper stack without bending it.
  3. Inspect the Paper Feed Mechanism
    • Look for any obstructions in the paper feed area.
    • Ensure that the rollers are clean and free from debris.
  4. Restart the Printer
    • Turn off the printer and unplug it for a few minutes.
    • Plug it back in and turn it on to reset the system.
Additional Considerations
If the error persists after following these steps, it may indicate a more serious mechanical issue. In such cases, consulting the printer's manual or contacting Canon support for further assistance is recommended.
