06-07-2023
04:55 PM
06:08 PM
Tiffany
When I try to print, it says printer not available. I have tried power cycling printer and modem, and connecting to a different WiFi source.
07-03-2023 11:56 AM
07-03-2023 12:16 PM
Stephen, I don't necessarily need to print right now. I was just hoping someone would come up with something
07-05-2023 08:09 AM
If the printer is reconnected and the signal strength is below 60%, I would recommend moving the printer closer to the router if possible. If a printer has to low of a signal strength, the computer can give off a false offline error when trying to print. Even though the printer is connected, because the signal is so low, the computer reacts like the printer is offline.
07-05-2023 09:12 AM
I got a solution from outside the forum. Thanks
03-05-2024 07:31 PM
My printer is literally touching my router.
03-05-2024 07:32 PM
Please share, I'm having the same problem.
06-07-2024 03:06 PM
Yes. Please share. I’m having the same issue. On 2 different printers! It’s driving me crazy now.
09-13-2026 10:41 AM
Yes this is a late reply, but just got a new TS3720 and while I'm able to print items from my phone that I can browse to through the canon app, I received 'printer not available' when I tried to print an email and selected the printer from a list.
Only thing that worked for me was using a default print service from Mobile Dynamix called Printer Share Mobile Print, an app from Google Play. Works for both my ancient HP toner officehet, and this brand new Pixma. I ain't gots time ta be playin with this stuff.
