06-07-2023
04:55 PM
06:08 PM
Tiffany
When I try to print, it says printer not available. I have tried power cycling printer and modem, and connecting to a different WiFi source.
06-07-2023
04:59 PM
08:53 AM
Welcome to the Canon forum!
So that the Community can help you better, please let us know whether you're using the PIXMA MG3522 or the PIXMA TS3522. We will also need to know which operating system is running on your computer (i.e. Windows or macOS and which version) and how they talk to one another. Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
06-08-2023 06:03 PM
I posted all of this in my original post. It is a Pixma TS 3522, and I am printing wirelessly. I have tried it from both my computer (windows 11) and my android phone and neither worked, same error both times. It printed when I first set it up, now it just says "printer not available."
06-13-2023 01:41 PM
Please use the steps HERE to try and print the network settings page directly from the printer. Once it prints, check the following:
06-13-2023 02:24 PM
I'll check those things. If they are all in line, then I'm going to try a factory reset. If they are not, how do I set them to the correct settings?
06-13-2023 03:51 PM
If they are not correct or missing, you will need to reconnect your printer to your network. Please click HERE and scroll down to the wireless help option. This will provide you with different options to connect the printer back to your network.
06-13-2023 04:24 PM
I've already disconnected and reconnected the network. Yes, all of those things that you listed are correct. Ip address starts with 192, signal strength is 49%. I'm going to try a factory reset, because right now this thing is a $50 paper weight.
06-13-2023 04:35 PM
I did the factory reset, and now I can't get it to connect to WiFi at all
06-18-2023 07:35 PM
I have tried all of your suggestions, and finally reset my printer to factory. After two days of trying to find how to reconnect the wifi on the canon site, I finally gave up and googled it. This provided me with the answer. I am now back to square one. Printer on, connected to wifi, gives an error when I try to print.
07-02-2023 04:57 PM
Does anyone else have anything to say on this topic? I'm getting pretty fed up with not being able to use my printer
