PIXMA TS3520 how to make copy density darker
S4129
Is there a way to adjust the copy density to make it darker?  I can't seem to find the menu for that (if there is one) on any of the control panel buttons.
1 REPLY 1
Patrick
Hi S4129,
Adjustments to the density to make a copy lighter or darker are not available when using the operation panel of your PIXMA TS3520 when making copies.
Please use a Windows or Mac computer and the IJ Scan Utility.  Once you scan the item to your computer, you can then print it with the desired adjustments.
More information regarding copying can be found here:
https://ij.manual.canon/ij/webmanual/Manual/All/TS3500%20series/EN/CNT/cnt_scan.html
