05-28-2020 12:24 PM
I have a imageCLASS MF264dw. I'm trying to scan documents so that written and typed words come out darker and clearly. I currently have it at 300 dpi, but it comes out light and not really clear. And i don't want to increase the dpi because then the file will be bigger. I have scan docs in other printers at 200 dpi and they come out great.
The manual located here: http://gdlp01.c-wss.com/gds/0/0300031610/03/MF269dw_UsersGuide_usEN_2.pdf
On pg 252 of manual, there are 3 options to scan clearly by: Image Quality, Density and Sharpness. When I go to the Sharpness instructions on pg 255, it says to do the following for scanning sharpness:
Scan -> Specify Destination -> <Sharpness> ->Adjust Sharpness -> Apply
However, the Sharpness and Density options only shows up on the Copy screen. On Scan screen, it's not listed, and only allows me to choose: Color, B&W scan, Custom 1 and Custom 2.
The MFScan Utility does not allow me to set Sharpness or Denisty settings either.
So are these instructions a misprint in the manual, and therefore this printer does not have the option to set Denisty and Sharpness for scanning? Or there is a way to set those in this scanner?
05-29-2020 12:48 PM
Hi dplaza00.
Those settings are used when scanning from the MF264dw's operation panel. Information on scanning from the MF Scan Utility may be found in the software's own online manual:
https://oip.manual.canon/USRMA-1480-zz-DR-enUV/frame_htmls/home.html
