PIXMA TS3120 Paper comes out blank
lorsue
My TS3120 wireless printer will not print the paper comes out blank it does not show it is low on it. It shows an E but I know were it is. I am 85 and tech challenged. Have had this printer awhile but do not know were the manual is. There is a yellow triangle lit up with what looks like a lightening in it. If I could even get a support number to call it would help as can usually follow directions.
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, lorsue!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
lorsue
The box is flashing the L A4 TS3120
I would recommend trying to resolve this issue in real time with Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
Friends and Family
