PIXMA TS302a power and wireless button blinking yellow
Southparklyla
I just got the cannon PIXMA ts302a and recently the power button and wireless button just keep blinking yellow and I tried unplugging it and nothing won’t help what can I do?
1 REPLY 1
DerrickL
  • Check for Paper Jam: Open the rear cover to check for jammed paper, ensuring the rear tray and output area are clear.
  • Check Ink Cartridges: Open the scanning unit/cover, remove both cartridges, and firmly reinstall them until they lock into place. Ensure all protective tape is removed.
  • Clear Error Codes: If the light flashes in a specific pattern (e.g., 16 times), it indicates that ink is low or out, requiring a cartridge replacement.
  • Restart/Reset: Turn off the printer and unplug it from the power source for about 10 minutes to reset internal components.
  • Check Wi-Fi: If the wireless light is flashing, it might be in setup mode or having connection issues. Press the "Stop" button to cancel errors.
