11-29-2025
05:33 PM
05:40 PM
SamanthaW
I just recently moved and was resetting up my computer set up and my Canon TR8600 printer will print if I am able to do like a scan but if I try to print a document off of my computer screen, it says that it’s not responding. I am doing a hardwired connection with the appropriate cable into the USB port on the back of my computer.
I do not have my Internet set up, but that shouldn’t make an issue if I just wanna print something off of my computer like a saved document or whatever. At least that’s what I thought.
Am I going to have to delete the printer and then start over again or something. I won’t be able to download any drivers til I get my internet setup. So that’s my issue like I don’t wanna try to go forward and end up going backwards.
11-29-2025 06:30 PM
Well, for some reason I plugged into the wrong USB outlet. I messed around with the different ones that I have and finally got it to work. I’m just hoping no other settings got messed up
11-29-2025 05:37 PM
Hi!
To have a better understanding of your issue, please let everyone know the specific printer model you’re working with in the TR8600 series along with any other information you think might be helpful for the Community to know.
If this is a time-sensitive matter, please check out your other support options here.
Thanks!
11-29-2025 05:38 PM
TR8620a is my modell
11-29-2025 05:44 PM
How was your printer connected? Wifi connection drops often due to various issues, so I suggest you connect using a printer/usb cable. Usually when using a USB windows will see the printer and install basic drivers, if installed previously then changing from wireless to USB then this may help:
Turn on the Printer: Make sure the printer is powered on.
Access the Printer Menu:
Select LAN Settings:
Disable Wireless:
By following these steps, your Canon TR8600 should now be successfully connected via USB.
11-29-2025 06:30 PM
