10-14-2025
12:23 PM
09:17 AM
Mac Sequioa / TR8620a / Dual feeders / Differentiate printing
Currently using a Mac (Sequioa) with a TR8620a. It has dual feeders, and I want to make the most use of that. I want to be able to put letter paper in the cartridge, and letter sized labels in the rear feeder. The problem is while I can create a custom paper size in the Mac, if I tell the printer it has letter in front and back, it picks the back for anything letter. I tried setting the back to "Other/Other" with a custom paper size, and it didn't take it.
How can I set it up to control 2 different letter size paper when it doesn't have "Letter1" and "Letter2"
Thanks
10-17-2025 01:38 PM
Please turn off the paper mismatch setting on the printer using the steps HERE.
If the issue persists, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
10-17-2025 01:38 PM
