07-08-2025
09:03 AM
09:46 AM
Hi all! As the title says I have a Pixma TR8620a printer and this morning I was making a large batch of stickers for my small shop and everything was going perfectly. Then my printer ink ran low and I changed it using the exact same ink/brand I always have used. I printed everything out with the settings as I usually do but all of a sudden the colors are EXTREMELY off. I don't know if it's possible the ink is a weird batch??? I've tried running almost every maintenance & cleaning setting and I'm just so confused as to what happened?
Anyone experience this before? Any and all advice appreciated!
07-15-2025 05:28 PM
Hi laurak34,
Canon USA does not recommend the use of inks manufactured by third parties in Canon printers.
Canon genuine inks are formulated specifically for use in the ultra-precise print head. The print head and inks work together as a precisely engineered system to support optimum image quality, print speed and reliability in higher resolution text and color printing applications.
Canon supplies and accessories can be purchased online at http://shop.usa.canon.com, or by calling 1-800-385-2155 to speak to a Canon Direct Representative.
Should you decide to use inks manufactured by third parties in your Canon printer, and such inks cause damage to your product, this damage will not be covered under the product's limited warranty. Any repairs required as a result of such damage must be made at your expense.
