PIXMA TR8620 and PIXMA TS8220 produces blank pages when copying; Scanning and printing OK
billolga
I have two pixma printers a 8620 and a 8220.  Both have stopped printing when I copy something.  The scanner works - I see a preview, but blank pages come out when I ask for a copy.  The printer prints data from the computer, but will not print in copy mode.  They used to print copies.   Has there been an update to the printers that has interferred with the copy mode somehow?   I went through the settings - checking all of them - every thing seems OK.
Any suggestions?  or do I need to buy a new printer.....
Thanks,
Olga Wilson
5 REPLIES 5
Moderator
Moderator
Thanks for joining the conversation, Olga!
So that the Community can help you better, we need to know exactly which Canon printer models you're using.   It sounds like one of your printers is the PIXMA TR8620 but we need some clarification on the other printer as we have more than one model with the number 8220 in their name.  Do you have the PIXMA MG8220 or the PIXMA TS8220?  That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
billolga
I apologize - I have a Pixma TR8620 along with a Pixma TS8220.
Thanks,  Olga
Patrick
Hi billolga,
First, let's perform a test of your PIXMA TS8220:
1.  Please turn your PIXMA TS8220 on.
2.  Tap the gear icon at the bottom of your printer's display.  Patrick_0-1741964281959.jpegPatrick_0-1741964281959.jpeg
3.  Tap Maintenace.
4.  Tap Print nozzle check pattern.
Does your printout match the example below?
Next, we will perform the same test with your PIXMA TR8620:
1.  Please turn your PIXMA TR8620 on.
2.  Please tap the gear at the bottom of the display of your printer. Patrick_0-1741964281959.jpegPatrick_0-1741964281959.jpeg
3.  Tap Maintenance.
4.  Tap Nozzle check.
5.  Tap Yes.
Does the printout from your PIXMA TR8620 match the example below?
If the test from your PIXMA TS8220 did not print correctly, please follow the steps on this page from the manual to resolve it:
TS8200 series > Maintenance > If Printing Is Faint or Uneven > Maintenance Procedure
If the test from your PIXMA TR8620 did not print correctly, please follow the steps on this page from the manual to resolve it:
TR8600 series > Maintenance > If Printing Is Faint or Uneven > Maintenance Procedure
If your printer does not print correctly after following the steps provided above, it would require service.  If your Canon printer was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your Canon product's name and then click on the Product Support button.  When that page loads, click on either the Phone Support button or the Chat Support button to access support.
If your Canon printer is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
billolga
ThePIXMA TR8620 nozzle test pattern printed out 6 rows of colored rectangles - the C C M M Yand BK part. There were no lines at all at the top or PGBK printed.  The TS8200 series printed all the lines - and now will print a copy instead of sending out a blank page.  I will contact Cannon about replacing the TR8620.  Thanks so much for your time and attention to my problem.  Sincerely,  Olga Wilson
billolga
Update:  I bought a new printer
