03-17-2022 08:17 AM
After cleaning the printer head and printing a nozzle pattern and replacing both black ink cartridges. The printer still does not print "black". The nozzle check pattern does print the colored lines but no check pattern at time. Please advise as to what this might be.
Would a new Printer Head be a solution? a new Printer?
Thank you
Denise
03-28-2022 03:23 PM
Hi Dmarie,
Please open the cover to your PIXMA TR8520 and remove the PGBK ink tank. Please verify that all of the tape/cellophane has been removed from the ink tank and then reinsert the ink tank back into your PIXMA TR8520 and close the cover.
Please attempt to print. If black is still missing, please perform 2 deep cleanings:
1. Please tap the gear at the bottom of the display of your PIXMA TR8520.
2. Tap Maintenance.
3. Tap Deep Cleaning.
4. Tap Yes.
After 2 cleanings, if black still does not print, your PIXMA TR8520 would require service. If your PIXMA TR8520 was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
If your PIXMA TR8520 is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
