04-09-2026
03:12 PM
11:26 PM
Tiffany
Half the time this printer simply refuses to print. Today I absolutely had to print some documents, and I can't.
Juist so frustrating.
Everything is updated on my computer on a weekly basis, so it's not the drivers.
Can someone recommend a printer brand that is actually reliable enough to count on? Because this is my second PIXMA and they have both been equally unreliable.
04-09-2026 03:47 PM - edited 04-09-2026 03:49 PM
What happens when you try to print? What operating system are you using? Many times it is not the printer causing the issue.
04-09-2026 07:56 PM
I doubt it's the Operating system (Win 11).
It's the unpredictability of it. Sometimes it works, sometimes it doesn't. Sometimes it will work if I turn it off and on a couple of times. Sometimes it sounds like it's going to work but then doesn't.
My print jobs are visible but they don't print.
04-09-2026 09:46 PM
@Laura99 ,
How is the printer connected and to what? USB, WiFi?
04-10-2026 01:44 AM
It's Wifi. But it used to be via USB, same issues.
04-10-2026 02:32 PM
It could very well be a Windows problem, sounds like a print spooler issue.
Windows key + R, type services.msc, and hit Enter.Locate the Print Spooler service in the list.
Right-click on Print Spooler and select Stop.
C:\Windows\System32\spool\PRINTERS03/17/2026: New firmware updates are available.
