07-08-2017 01:20 PM
07-08-2017 03:34 PM
11-22-2019 11:43 AM
I just tried this and it worked. wow i didnt think it would but i was shocked because its was a simple fix on an issue i have been trying to fix for 2 days. I was about to try and take the head off before is saw this thread. thanks for the help.
01-05-2020 06:45 PM
Thanks for the tip. This worked for me as well.
cheers
01-06-2020 06:56 PM
Thanks for the two comments. I ordered a new Canon QY6-0086 printhead since all indications were that the MX922 printer was fundamentally okay.
I reiterate that the longterm problem with the printer has been a diverging vertical pattern in the PGBK section of the head alignment test sheet. This caused shadow double printing that appeared every two or three lines in pages of text. I tried to clean the printhead but that only caused the B200 error to appear.
Without any clear solution to the B200 that worked for me, I ordered and installed the new Canon printhead. The printer now works like new again.
Thanks to all on the forum.
01-18-2020 02:29 PM
Thank you very much! It worked for me
02-23-2020 05:57 PM
Thank you for the solution. Had to do it twice byt it WORKED!
Now I have two MX922 that print some text rows in double images unless I select Matte paper or print all documents even black and white ones by selecting color. Anyone have a solution for this. I understand that Canon is blaming warped print heads. But how do they warp overnight and not progressively. Both machines have exactly the same offset.
03-17-2020 01:15 PM
Brilliant and THANK YOU!!!!
04-01-2020 04:07 PM
If this procedure clears the error but then it re-appears when you go to print try performing a deep cleaning from the maintenance menu right after you clear the error. This approach resolved the issue completely for me and the printer returned to printing without any issues.
04-21-2020 04:57 PM
Hello! Thank you for sharing this solution. I have an MX922 and your solution worked like a charm...just when I thought all hope was lost.
Thanks!
04-21-2020 10:16 PM
Thanks for your suggestion. Tried it on two double black printing MX922 with no success. Have new print head on order. Will post after test.
08-20-2020 05:45 PM
