PIXMA MX922 unusual PGBK alignment pattern
Doc_Ondrusek
My MX922 suddenly started printing blurry black text. The alignment pattern shows a very unusual horizontal divergence pattern, almost as if it is an intentional pattern:
Has anyone ever seen this pattern? Note how the first divergence (3rd row) forms a perfect inverted "V" - the double lines are perfectly vertical until the 3rd last row where the converge again in a perfect "V" shape.
This seems too "perfect" to be a faulty head; I'm suspecting a software or firmware issue. Anyone else ever see (and hopefully resolve) this?
Everything else about the print, including the other colors, all work fine.
Thanks in advance. Doc.
21 REPLIES 21
Doc_Ondrusek
Clearly, there is no solution to the PGBK problem. My suspicion is that it is a built in obsolescence fault in the firmware. An intentional fail to get you to spend for service or a replacement printer. So I scrapped it and bought a new HP smart tank. It's excellent, and a bottle of ink to refill the tanks costs less than a cartridge that holds a tiny fraction of the ink.
Thanks so much for the reply!
