PIXMA MX922 failure to recognize magenta ink cartridge
Tommy2721
My printer will not recognize a new Canon ink cartridge. As near as I can tell, all contacts are mating with the new cartridge, but the light doesn't come one and the printer reports the cartridge is unrecognizable.  The print then is unable to do anything.
What can I do to fix this?
4 REPLIES 4
Patrick
Hi Tommy2721,
When you insert the ink tank and close the cover, does a Support Code appear on the display of your PIXMA MX922?
Please take a photo of the ink tanks installed in your printer and then please reply to this post with that image.
DerrickL
Troubleshooting Canon PIXMA MX922 Ink Cartridge Recognition
If your Canon PIXMA MX922 is not recognizing a new magenta ink cartridge, follow these steps to resolve the issue.
Initial Checks
  1. Proper Installation
    • Ensure the cartridge is installed correctly. Remove and reinsert it, making sure it clicks into place.
  2. Remove Protective Tape
    • Check for any protective tape on the cartridge that may not have been removed. This tape can block ink flow.
  3. Clean Contacts
    • Inspect the metal contacts on both the cartridge and the printer. Clean them gently with a lint-free cloth to remove any dust or ink residue.
  4. Restart the Printer
    • Power off the printer, wait a few seconds, and then turn it back on. This can refresh the printer's system and may resolve recognition issues.
    • If this does not resolve the problem it is possible you have a bad cartridge. If the original magenta cartridge can be reinstalled and lights up, you will need a replacement magenta cartridge.
I'm afraid that patience is not one of my strong suits. After no interest expressed in the issue, I did use an AI type function under Amazon where I got much the same advice. The printer would never let me anywhere near a system reset because the cartridge issue would come up first and there was nothing I could do about. I liked the printer, but, alas, I took it to the recycle facility two weeks ago. The printer I bought when the issue first came up has been replaced by a Canon GX2020 which I'm happy with.
DerrickL
Good choice, especially for a tank printer.
