11-28-2016 07:32 PM
I am getting a support code 6000 message. My priter cue is empty. I have shut down the machine and power source and the message still appears when I power it back up. The machine has no functionality with this code present.
11-30-2016 09:15 AM
Hi Barryjsiegel,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
03-03-2020 12:48 PM
03-04-2020 05:54 PM - edited 03-04-2020 05:56 PM
Hi, AnnZ.
Support options have changed since the previous Subject Matter Expert post in this thread, our support policy has changed. Canon community accounts only apply to the forum. A Canon Account for product support is managed through a separate system, located through http://mycanon.usa.canon.com.
One initial check that may resolve the 6000 error is to check the rear hatch for jammed paper.
03-05-2020 08:49 PM
This absolutely DID NOT help.
I have a Canon Account for product support.
I DO NOT HAVE A PAPER JAM.
Does this mean that my printer software has suffered a fatal exception and I'm SOL?
03-06-2020 01:51 PM
Hi AnnZ.
If all else has been checked, and the 6000 error persists, then the printer's hardware is suffering a problem, and the printer will need to be replaced.
One option I can offer is the Canon Upgrade Program. The Canon Upgrade Program provides a one-time discount on the purchase of a replacement printer directly through Canon U.S.A., and comes with free ground shipping.
If you're interested, you may call one of our phone-based Canon Direct agents at (866) 443-8002. You will need to have the printer's serial number for this call; the serial number may be found on the back of or inside the front of the printer. Please keep in mind, you are under no obligation to take advantage of this offer immediately to gain the information.
