09-25-2014
01:04 PM
09:40 AM
I have a Cannon MX922, i am getting code "5011" cancel printing. Turn off and plug in, if problem persist call support. I did so and i am asking for help. did not work.
11-02-2017 11:43 AM
Thank you so much. Sorry, I don't see the accept as solution button. The printer DID come back fine tho after it was off for a couple days. Maybe I didn't follow the instructions correctly the first time. Thank you for your help. I do appreciate you.
11-02-2017 02:16 PM
12-21-2018 04:51 PM
Error 5011
I bought a new MG6852 and want to start, but it's not working. I directly get the message Support code 5011.
I turned the device off and tried again. But every time the same message
08-19-2019 02:44 PM
thanks a lot this really assisted me wow I almost took it back to the supplier
10-20-2019 11:47 AM
Apparently, when you tell Canon here what you really think of their product, they delete your post.
Let's see how long this one lasts under our freedom of expression rights
02-14-2020 07:39 PM
Buenas tardes, tengo una canon pixma TS9120 con codigo 5011, ya revise y no encuentro nada que obstruya el paaso de la hoja. ¿que puedo Hacer?
04-28-2020 08:48 PM
Garbage printer. Replace the black ink for the first time and get 5011 error. Have done everything in this thread. Nothing. DO NOT EVER BUY A CANON PRINTER.
05-18-2023 05:26 PM
I had this error code as well, to fix this issue power off and unplug it before it gets shut down all the way. I tried to power off and unplug it but didn't work so I decided to try power off and unplug before it shuts off, it worked on mine. Hope this helps everyone who has error code 5011
06-12-2023 07:12 PM
What exactly did you do? It sounds like you found a solution but I seen no real solution posted here.
