11-21-2018 03:09 PM
EVERY TIME I PRINT SOMETHING THE COLOR IS ALL PINK. I HAVE RAN ALL THE MAINTENANCE CLEANING PROCEDURES. AND ALL INK TANKS ARE FULL. PLEASE HELP ME.
11-21-2018 03:20 PM - edited 11-21-2018 03:21 PM
Hello!
So that the Community can help you better, we will need to know about any error messages you're seeing, and the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
Please click HERE for self-help options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
11-21-2018 03:31 PM
I AM USING WINDOWS 10
NO ERROR MESSAGES
I AM CONNECTED BY USB
11-21-2018 03:37 PM
WHEN I RAN A PPRINTHEAD ALIGNMENT TEST PAGE IT DID NOT SHOW ANY BLUE INK OR YELLOW INK
11-22-2018 08:32 AM
Two most common reasons for this:
Clogged print head, or applying double color management during output.
If you run a print head alignment or cleaning, and two of your colors don't print, start there.
After, ensure the program you are using on your workflow is processing the output prior to being sent to the printer or viceversa.
