07-06-2013
10:41 AM
08:49 AM
I tried to print a web page wirelessly from my iPad on my canon mg 5320. I have had no problem before. Now it says error, cassette. There is no paper. Load paper then push start. I had plenty of paper loaded. I reloaded and pushed start...same message
07-06-2013 11:24 AM
07-08-2013 08:21 PM
Hi Emmrut,
If you have already verified that there are no paper jams or obstructions in the printer, ensured that the paper guides in the cassette are snug against the paper, and have performed at least three roller cleanings on the printer and are still experiencing the same issue, the printer will require servicing. Please click on the Contact Us link below to obtain your servicing options.
This didn't answer your question or issue? Find more help at Contact Us .
11-14-2014 04:47 AM
dear team I have a problem when I am printing to Cannon ir2520 the is error number 0276 printer load paper . Please I assist to resolve this
thanks
06-19-2015 12:35 PM
09-05-2015 02:58 PM
@gedeon
I am curious as to where exactly I can find settings to select in order to follow your advice please??
09-08-2015 10:04 AM
Hello.
From the Home menu, select "Setup". From there you can select "Device Settings" to access the Plain Paper Feed Settings adjustment.
If additional assistance is needed, find more help at Contact Us.
11-18-2015 10:09 PM
Yes!! Thank you so much! That is exactly what I needed to solve this.
Great - thanks again!
02-01-2016 05:14 AM
I tried to print tickets online. When i brought up the printer i noticed it said paper size was 4 x 6. I reset it to letter and that fixed the problem.
07-28-2016 02:18 PM
I opened the home page, saw Printer Setup and clicked on it with four choices
General, Driver, Supply levels and Utility
I can't find Device Settings
