06-15-2024 07:05 AM - last edited on 06-15-2024 09:44 AM by Danny
My ink absorber is full - I've over-ridden it many times and now I just get a 5B02 error - contact the service centre.
This is a cheap printer so I bought a new similar model to replace it so I can carry on using the ink cartridges - which are almost as expensive as the printer!
But now I can't get the old cartridges out. The printer will not let me get at them.
Any ideas how I can either get the printer to put them in a removable position?
06-15-2024 08:30 AM
Thanks for joining the conversation, battlebus!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
06-15-2024 09:14 AM
Its an MG4200 series - not sure of the exact number
06-15-2024 09:16 AM
That's a step in the right direction! The printer's exact model number should appear on the front of the printer at the upper right. Mind taking a look?
06-15-2024 09:42 AM
G4250 - how did I miss that?!
06-15-2024 09:42 AM
MG4250
06-15-2024 10:41 AM - edited 06-15-2024 02:38 PM
When you open the front cover when the power is on, the cartridge carrier should move to the left, pause, then move to the right. I'm not sure if you can re-use the cartridges in another printer (same model) but you could try.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
06-15-2024 10:54 AM
"When you open the front cover when the power is on, the cartridge carrier should move to the left, pause, then move to the right"
This is the problem - the error message is stopping this from happening
06-15-2024 03:12 PM
I understand. You can only bypass the ink absorber almost full error a limited number of times. Then, the printer will not operate. You might have bypassed yourself into this state.
06-16-2024 03:14 PM
This much I know!
I was hoping someone helpful from Canon would chip in with a solution. Short of that I'll have to take a crowbar to it.
