PIXMA MG3620 printer blue will not print
EHP
great little printer is refusing to print in blue - so much read
have gone through all the suggestions any help greatly appreciated
done the deep clean, nozzle clean - taken the ink out put it back in
on check the top line C is completely empty
the second line C is sold and light blue the magenta and yellow look fine
8 REPLIES 8
Moderator
Moderator
Thanks for joining the conversation, EHP!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA MG3600 series.  The model number should appear on the front of the unit at the lower right corner. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
EHP
IT IS A   MG3620
SignifDigits
Canon cartridge or third party?
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using no Adobe products.
DerrickL
There are two cyan nozzles, one seems to be clogged, did you deep clean the nozzles?
Several times but no change : (
it is third party but I've used it before no issues
DerrickL
As an MG3620 owner, I think and hope I am right, your color cartridge has one ink chamber either empty or defective, in other words it needs to be replaced.
EHP
thank you, I fear you are correct : (
