PIXMA MG3620 not grabbing paper, thinks there's no paper
grantpaige804
My MG3600 Pixma Printer is not grabbing paper when it is loaded in the proper place with the proper adjustments. Each time I try and print something, it says there's no paper when there's more than enough. Please help as this is crucial as a student and employee.
I have also switched out the ink to brand new cartridges as my Mac printer queue was displaying this at first, but now it's saying "Printer needs paper" and the triangle is flashing on the printer itself, even though there's more than enough paper in there.
Please advise
12 REPLIES 12
Moderator
Moderator
Thanks for joining the conversation, grantpaige804!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA MG3600 series.  The model number should be on the front of the printer at the lower right. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
grantpaige804
Hi!
Thank you for reaching back out so quickly.
I am using the Wireless Pixma MG3620 series in black.
grantpaige804
I have also tried both of these instructions multiple times. One piece of paper ended up going through, but I received blank pages each time. After that, I tried to print a normal document and the same thing occurred after cleaning:
1. Went to document and pressed "Print" (about 2 pages total)
2. Printer queue for Mac showed up
3. Queue said it was printing
4. Printer grabbed a page
5. Page turned out blank
6. Went back to printer queue on Mac and says "printer needs paper".
Screenshot 2024-02-29 at 11.31.26 AM.pngScreenshot 2024-02-29 at 11.31.26 AM.pngScreenshot 2024-02-29 at 11.30.27 AM.pngScreenshot 2024-02-29 at 11.30.27 AM.png
Hey Danny, please see my replies below. I am still having issues with my printer even though I have been through all troubleshooting steps multiple times.
Since the page was feed through but cam out blank, hold down the Stop button on the printer until the Alarm lamp flashes once and immediately release it .
If it prints, please let us know if it looks like the example HERE.
the1mikeo
I had the exact same problem with my MG3600 and one of the instructions here said to press the black or color copy and that finally got the printer to work. Sometimes you have to press one of those button 10 times to get just one copy made but it will work.
PixmaMG3320
Did anyone figure this out? My printer MX3620 is telling me there's no paper in the machine, but there is. I barely use this thing. I used in once in the last 2 years for taxes last April 25. There's nothing in there it's completely clean, but I don't know if there's a sensor in there that's not working or if it's a mechanical trigger with the paper going in.
I know this is an old thread but it just happened to my Canon 3620 printer.  My printer is 8 years old but has been working really well.  I'd really like a fix to keep it going for a bit because I just got new ink for it last month and don't want to have to buy a new printer like the Canon TR4720 because the inks aren't compatible between them.
DerrickL
First thing is to inspect the inside of the printer make sure there are no small scrapes of paper, or other obstacles in the paper path. If that looks clear then run the clean roller program from the maintenance settings. Here is the guide:
https://support.usa.canon.com/kb/s/article/ART162678
This video may help you as well,  the mg3220 is physically the same as an MG3620.
https://youtu.be/BTD8wmDZhA8
