PIXMA MG3620 How to Scan Slides?
RonC1
Hello and thank you. Can I scan slides using the Pixma MG 3620 printer/scanner? If so, how? Thanks again.
DerrickL
The Canon PIXMA MG3620 is a flatbed scanner designed for documents and photos, not specialized for transparent film or slides. While it cannot directly scan slides due to a lack of a transparency unit (light source), you may attempt to scan them by placing them on the glass, using a backlight source, and selecting high-resolution (600+ DPI) settings in the IJ Scan Utility.
Steps for Attempting Slide Scans:
  1. Place Slides: Open the scanner lid, place the slides directly onto the scanner glass (platen).
  2. Add Backlight: Because the printer lid does not have a built-in backlight, you must place a small, flat, bright light source directly behind the slide, or the scan will be black.
  3. Use Software: Open the Canon IJ Scan Utility on your computer.
  4. Scan Settings: Select Photo mode and choose a high resolution (600 dpi or higher) for better detail.
  5. Crop & Adjust: Scan, then use editing software to crop the slide and adjust colors, as the colors may appear inverted or washed out without a dedicated film scanner.
2 REPLIES 2
DerrickL
Thanks so much for the quick reply! I will give it a try.
