04-28-2026
09:09 AM
09:39 AM
James_C
I purchased this printer in August 2025. Recently it would not print and it flashed warning three times that it had to do with the ink cartridge. I am unable to change the cartridge as they move to the right but will not lock in the position so I can change the cartridges, it just moves back to the left??
04-28-2026 09:49 AM
I own an MG3620 also, the three lights indicate a paper jam, whatever is in the paper path will keep the cartridges from moving to the right and the small compartment door from opening. Use a flashlight and check closely, the cause may not be all that obvious.
04-28-2026 09:49 AM
04-28-2026 11:08 AM
I will look again. But the ink cartridges move all the way to the right and door does open, the cartridges then move to left without stopping
