03-12-2024 02:53 PM
Hi, I have a MG2922 and it prints fine via USB with my Dell Inspiron but I am trying to use my work laptop which is a Lenovo Thinkpad with Windows 11 and it just doesn't show up on my list of printers when I go to print something. I tried to install the latest driver for the printer with Windows 11 but it doesn't recognize the printer via USB and says "cannot detect" even though I follow the steps (close applications, turn off printer, then plug in + turn on) so I am unable to download it.
09-12-2024 02:33 PM
Hi! Thanks for posting in the Canon Community Forum. I see that you are unable to install your Canon PIXMA MG2922 on your Windows 11 computer.
Please look at the lamps (lights) on the printer. If the Power lamp or Orange Alarm lamp are blinking, the printer may be experiencing an error. You won’t be able to install the printer while it is in an error state. For information on the possible errors that your printer can experience, please visit the following section of the manual:
https://ij.manual.canon/ij/webmanual/Manual/W/MG2900%20series/EN/UG/ug_trouble0300.html
If the printer is not experiencing an error, I recommend uninstalling the printer driver, restarting your computer, and then reinstalling. Before you start uninstalling, it is important to disconnect the USB cable and leave it disconnected. Please leave that cable disconnected until the setup program starts searching for the printer.
To get started, please follow these steps to delete the printer and uninstall the driver:
When your done following the above steps, please open the following website:
https://www.usa.canon.com/support/p/pixma-mg2922
After the web page opens, please click on SOFTWARE & DRIVERS to the right of the picture of your printer. Then, look for the detected Operating System and Version below the section titled Downloads. Please make sure that you see Windows 11 under Version.
Below that, you’ll see a list of Software & Drivers (showing 8 of 9 results). Please scroll down and look for third option (titled Print Driver and Scan Utility Installer Ver. 1.01).
Please click on the DOWNLOAD button to the right of the Print Driver and Scan Utility Installer Ver. 1.01. When it finishes downloading, please run it and follow the instructions. You should be able to select a USB Connection option. Please do not connect the USB cable until that program tells you to turn the printer on and connect the cable or when the program starts searching for the printer.
When the installation is complete, you will be able to use the printer.
Here are a few other helpful hints that you may help during the installation:
I hope this information helps. Thanks for choosing Canon.
11-19-2024 02:59 PM
Hello,
I have this same issues (but with Windows 10). I have followed all the steps above, but during the installation process, I still get the "the printer is detected, please wait until the installation is completed. " Then it says that it is processing the installation and to wait a few more moments. Then, it goes to "The printer is not connected. Check the connection."
Please help.
