11-04-2023
02:15 AM
08:14 AM
When I print a picture on 6 x 4 photo paper, I consistently get a border that is larger on the right than the other borders. Here's an example:Is this a limitation of the MG2560 printer or is there a workaround?
11-04-2023 07:38 AM
The image as shown has a ratio of 10:8 (1.25:1). So your image currently doesn't have the required width to fill the area once the height is filled. As John mentions, you'll want to look at cropping the image to have a 6:4 (1.5:1) ratio instead.
11-04-2023 07:25 AM
What software are you printing from?
Is the image cropped to a 4x6 aspect ratio?
11-04-2023 07:38 AM
11-04-2023 05:34 PM
I am using Paint.net to print and as you can see from the screenprint below I have resized image to 6X4 inches.
