07-02-2016 05:38 PM - last edited on 07-02-2016 05:55 PM by Jason
I DECIDED TO POST THE SOLUTION TO ERROR CODE 1660:
AFTER DAYS of inability to bypass error code 1660 (and I searched the entire cyber world to no avail) - "INK TANK IS NOT RECOGNIZED", I FINALLY discovered the solution, to this abyss of a problem, which does not require purchasing tons of new ink cartridges (which doesn't work-but pays Canon), which does not require a technician to come to your home/printer (for cost). which allows you the ability to return your printer to it's original reliable-printing, normal functioning device for which you originally purchased it for.
TITLE: the notorious ERROR CODE 1660 with Canon printers- TOTAL CONSUMER FRUSTRATION- SOLUTION HERE
04-08-2018 10:42 PM
The video is gone from YouTube - and they removed your email address as weel. I'm at the end of my rope. I've cleaned the pins - the contact - not sure how to remove the printer head to clean that but something has to fix this Support Code 1660 on this MG71200! Your help is appreciated.
05-13-2019 06:09 PM
The 1660 error code on my MG5420 was caused by a bent pin under the large PGBK cartridge. It was not making contact with one of the pads on the cartridge. If any of you has this problem, remove the cartridge and inspect the contact pads. The pads should have a tiny indentation where the contact pin hits the pad. The pins are VERY fragile and not well seated. I was able to reposition the errant pin with a small screwdriver push.
Funster
05-13-2019 06:21 PM
The solution posted by Jason is probably incorrect and his activity probably cured a contact problem as I noted in my last (and first) post to this site.
Funster
04-08-2020 01:38 PM
Here's somtehing that worked for me when my Cyan cartridge started to give the Error 1660 message after working fine for a long time.
Remove the cartridge.
Clean the pins in the slot with a q-tip dipped in 70% isopropyl alochol until they gleam. You can look at the pins for a functioning cartridg to compare.
Clean the contact points on the bottom of the cartridge with alcohol.
Check that the the pins in the slot are all in a line and not bent to one side or other.(see other posts about this) .
Press very gently on each pin (with tweezers or scissor points) from the front twoards the back of the cartridge slot.
Let everything dry for a few minutes.
Reinstall the cartridge by pressing down towards the back of the top of the cartridge, rather than towards the front.
I hope this works as well for you as it did for me.
