12-11-2022
02:09 PM
08:53 AM
My G3260 printer started displaying "Support code 495A". I have tried turning the printer off and back on numerous times and nothing changed. I have tried hitting the OK button - same result.
I tried reconnecting to my computer using https://ij.start.canon - no luck. I tried deleting all of the previously installed Canon software and starting over from scratch - ditto. I tried using the WiFi Connection Assistant -same result. I also tried connecting with a USB cable.
The problem is that when the instructions tell me to press the button to get to the place to select WiFi or USB, nothing changes on the screen - just keeps scrolling the 495A error message.
I would greatly appreciate any help or suggestions.
12-13-2022 12:36 PM
I recommend performing a reset of the printer. While the printer is on, unplug the power cord from the printer. While the power is off, press the power button 5 times. After 60 seconds plug the power cord back in and power on the printer.
12-13-2022 12:44 PM
Thank you for replying. In the interim I found out that my problem was the result of a defective chip, and Canon is replacing the printer with a new one, since it was still (barely) under warranty. Thanks again for your reply.
