PIXMA G3260 Stuck on Language Selection
sjburks
I have filled all 4 of the inkwells in my new Canon G3260 printer and the instructions say the printer prompt will change to "Are the ink tanks filled...". My prompt is stuck on Language selection of English. I have selected English and pressed OK. What am I doing wrong?
3 REPLIES 3
Patrick
Hi sjburks,
Please follow these steps:
When this appears, please press the OK button on your PIXMA G3260
When you press OK, the confirmation screen will appear:
"Cancel" is currently selected.  Use the left arrow to select "Yes":
Once Yes is selected, press OK
The language will be set to English and you will be able to continue with the setup process.
This does not work
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
