07-23-2015 06:23 PM
How do I set my PIXMA 922 to print in reverse order? I've set my MS Word print preferences for reverse order, but the printer starts at page 1.
07-23-2015 06:33 PM
Hello KLS!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
07-23-2015 09:13 PM
I am running Mac OS-X (v10.10.7). Trying to print a long Word doc in reverse order from my computer. How I've tried to fix this: I downloaded the print drivers, re-selected MX922 as my default printer. Set "reverse order" in the Word Preferences. In the "Print" dialog box, I choose "Paper Handling" and select "Reverse" order. None of this has helped.
NOW, in addition to NOT printing in Reverse Order, the printer is doing 2-sided, flipped order!! The Menu on the printer is set for 1-sided. I wrote about this same problem last year and got it fixed then. I don't know what has happened. I hope someone can help.
Thanks,
Karen
07-25-2015 12:36 PM
Hello.
Regarding the duplex printing issue, go to the Layout section of the print menu to disable duplex or double sided printing.
If the Reverse order option was a;ready selected in the Paper Handling section, the issue may be related to the document. Does this occur when you print in other programs?
