10-03-2013 10:14 AM
I recently purchased the PIXMA 922 and have been having issues printing. I have put standard Staples copy paper in the lower tray. When I go to print it will sometimes print a page or two, then it gives me "Support Code 1008" error saying there is no paper. I have to open the lower tray, readjust the paper a bit, hit ok. At that point its about a 40% chance of printing another page or two, otherwise it thinks again and then gives the same error. It makes it almost impossible to print anything more then a couple pages since every few pages is spending a few minutes going back and forth with the printer. Did I get a lemon? Is there something I missed that would make it so the printer can't pick up the paper? Before I return the printer I wanted to try to get some assistance.
Thanks!
02-18-2016 11:43 PM
06-06-2016 08:22 PM
This answered my question perfectly. Within 5 minutes I was able to print a document as well as ever. Thanks!
Bill
12-13-2016 10:24 PM
Yes, I realized Chrome was sending the job to the wrong tray!!
07-29-2017 11:52 PM
What did you do?
07-30-2017 06:29 AM
I tried this solution over 10 times and my printer still does not work.
08-25-2017 12:24 AM
09-01-2017 07:30 AM
Good afternoon,
I am currently facing the same issue and wasnt able to fix it. Is there something I should do?
Thank you so much in advance,
Diogo
10-11-2017 02:25 PM
Hi WhyCanonWhy,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
10-11-2017 02:26 PM
Hi DiogoPassarinho,
What is the exact issue that you are experiencing with your PIXMA MX922?
04-12-2018 11:18 AM
My mx922 has recently been giving this error. No matter what type of paper I load, it is unable to load paper from lower tray. Is there any maintenance or troubleshooting I can do to fix?
