09-07-2020 12:02 PM
Is this panel suspose to close itself at some time after printing? It opens itself and it would make sense that it should close itself.
Thanks!
10-13-2020 12:27 PM
Hi Leeell,
The operation panel does not close by itself, it must be done manually.
09-07-2020 09:24 PM - edited 09-07-2020 09:29 PM
The motorized opening is documented. I'm not sure about closing.
Look at ECO settings on page 246 of your user guide
https://gdlp01.c-wss.com/gds/6/0300036856/01/TS8300ser_OnlineManual_Win_EN_V01.pdf
Auto power off. I believe the default is 240min. Try decreasing this duration and see if the panel closes. The countdown timer is reset each time the printer is used. So it needs to sit idle during countdown. Appreciate if you could confirm this and post your results.
09-08-2020 08:47 PM
Couldn't find anything in the manual about the operation panel self closing. Lowered the shutoff time to see if it would and it didn't. I can only assume that this is not a feature in this printer model. Just seems odd though that it isn't.
Thanks for the info.
10-13-2020 12:27 PM
Hi Leeell,
