My PIXMA TS3522 started printing only yellow
travistee
I bought new ink cartridges but it still prints only yellow.
I am trying to print black.
I replaced the black ink cartridge but it still prints the same yellow
is it the ink or something else,.?
5 REPLIES 5
DerrickL
You may need to clean the print head:
  1. Open the printer software on your computer.
  2. Select the Maintenance tab.
  3. Click on Clean Print Head.
I didn't know I have any printer software.
Does it use the printer cable to connect to the computer.
Where do I find this software?
I found the software and installed everything on my windows 11 pc.
It is able to print.  The test page printed black ink with no  problem.
When I try to print color I get the yellow instead of other colors.
Now that I downloaded everything to my windows 11 PC how do I find the head cleaning software
DerrickL
Go to windows start menu, then all, scroll down to Canon Utilites menu folder, click U printer assistant tool, use nozzle check to verify if you have a dirty printer head, if so, then use the deep cleaning function.
travistee
I'll try that if I can find it.
Anyway, it turns out that replacing the color ink with a new one is all it needed.
  • In the past when it ran out of ink it just went blank.  This yellow stuff is new.
  • The new software is good.  I wasn't able to print wirelessly now it works.
