06-03-2022
08:27 AM
08:58 AM
My printer is stuck. The buttons work for a few ties after plugging it in and then nothing works. There was a storm and a new modem was installed. Since then, no printer.
06-05-2022 10:55 AM
Hello,
We apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
06-03-2022 08:36 AM
Hi, BDORF!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
06-05-2022 10:43 AM
Cannon MX490, started recycling or being unresponsive around 6/1/22 as did many others,
06-05-2022 10:55 AM
Hello,
06-07-2022 05:15 PM
Yes the update worked at the last step I had to unplug the power not just turn off and back on. I worked at canon print drint they are known for bad software and just installing without testing
06-10-2022 04:03 PM
Thanks, it seemed to work so far!
