10-07-2015 03:04 AM
I have a Cannon MP530 that is suddenly printing in stripes. I did not change computers or operating systems. I'm on Windows 7 PC.
Traditional word documents print fine, but anything considered part picture part text....the picture part prints in stripes, both black and white and color.
I've tried regular printer head cleaning, deep cleaning...nothing has resolved it.
10-09-2015 09:47 AM
Hi lricks,
Please make sure that the installed ink tanks are correct and full of ink. The correct order is:
CLI-8BK Black
PGI-5 Black
CLI-8Y Yellow
CLI-8M Magenta
CLI-8C Cyan
Next, a test should be performed of your printer. The Nozzle Check pattern shows if each print head nozzle is operating properly. Please perform the following steps to print a Nozzle Check pattern:
1. Press the OPEN button to open the Output Tray.
2. Load letter-sized, plain paper in the Auto Sheet Feeder or the Cassette Tray.
3. Press the COPY button.
4. Press the MENU button repeatedly until 4. MAINTENANCE is displayed in the LCD.
5. Press the LEFT or RIGHT ARROW buttons until NOZZLE CHECK is displayed in the LCD below 4. MAINTENANCE, and then press OK. The nozzle check pattern is printed.
If the page prints incorrectly, printhead cleanings should be performed. An example of this test has been added to the bottom of this post. Please follow the instructions below to clean the printhead:
1. Press the MENU button repeatedly until 4. MAINTENANCE is displayed in the LCD.
2. Press the LEFT or RIGHT ARROW buttons until DEEP CLEANING is displayed in the LCD below 4. MAINTENANCE,
and then press OK.
After 3 or 4 cleanings, print another test page.
Does the test page print correctly?
10-11-2015 05:50 PM
Hi Patrick!
Thanks for your help.
My ink cartridges are installed correctly.
I printed the nozzle check and ran a minor and deep clean several tiimes. I printed the nozzle check again and the majority of it is still printing in stripes.
I performed a print-head alignment and then ran a nozzle check again...still mostly stripes.
What is odd is that it is not all stripes. Specifically, the bottom half of the PGBK section prints fully, and the top half of PGBK as well as all of the colors (including BK) print in horizontal stripes. The second C and the second M have a dark top half and a light bottom half. I wish I could upload a print of it for you to see.
What do you suggest next? I'm Windows 7, 64 bit, and having been using this printer with this configuration for a long time.
Laura
10-12-2015 08:38 AM
Hello.
If no improvement is seen after cleanings have been performed, please contact our support group for assistance. Use the "Contact Us" link below.
