07-15-2015 09:01 PM
07-17-2015 12:46 PM
Hello.
Since this has been an ongoing issue with your printer connection, please contact our support group for continued assistance. Use the Contact Us link below to get in touch with our support group.
07-17-2015 12:46 PM
Hello.
07-17-2015 10:25 PM
07-22-2015 06:39 PM
09-02-2017 05:12 PM
KRBJR,
I know your post was from 2015 BUT do you recall what the resolution was? The Canon tech had you change some settings?
Was it on the printer via that little window or on the PC in the Canon software?
My MX922 is no longer seen on the network (wired) and I never got wireless to work.
Thanks for your reply if you get this. Sorry to drag it up.
Larry
08-04-2015 07:54 PM - edited 08-04-2015 07:55 PM
My Canon Pixma MX922 will not print. It was working fine but won't work now. I keep getting a message stating that my computer can not find the printer on the network. The printer shows it's connected. I reinstalled the CD that came with it and under control panel the printer shows up as the default printer with a green check mark.
I can't figure out why it won't work.
When I print something it shows it spooling and then in the cache is shows error and the window pops up that says the printer can't be found.
Any suggestions?
thanks, Diane
08-04-2015 08:03 PM
Hi Diane,
To ensure the most accurate information is provided, we will need to know the version of Windows or in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
08-04-2015 09:24 PM
Windows 7, thank you.
Diane
08-05-2015 09:20 AM
Hello.
To try and resolve this issue, please uninstall the MX920 series MP Drivers and Canon IJ Network Tool. You can uninstall these items from the Programs and Features section of the Control Panel. Then try reinstalling the drivers to see if this helps.
08-05-2015 06:57 PM
I tried that and the computer still can not recognize the printer. I used the CD that came with it to reinstall it and all goes well until the very end when the last window pops up and says it can not find the printer.
I went and bought a new printer last night Canon MG5622 since it uses the same ink cartridges and I have a lot of of ink
I didn't want to waste. This printer installed easily and works great.
Not sure what happened with the other one but perhaps I'll pass it to my sister with the CD and see if it will install on
her computer.
thank you for your help, you're awesome for trying!
Diane
