11-26-2014 06:34 PM
I can't get the MF Tool box to acquire the scanner function. "A supported scanner is not installed."
I want to be able to start scans from my PC so that I can see/choose where they are being saved. Can canon software keep track of all scanned documents?
11-26-2014 06:44 PM - edited 11-26-2014 06:44 PM
Hi!
To ensure the most accurate information is provided, we will need to know the version of Windows in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
11-27-2014 02:02 AM
xp
11-28-2014 10:32 PM
Hi Mike78.
I will be glad to assist you.
Please note that a scanning option must be selected at the D530 first, before opening the MF Toolbox software. Please follow the instructions below to perform a scan:
1. Place documents.
NOTEWhen scanning from the platen glass:
- You can scan multiple documents only when
- [Save as Type] is set to [PDF (Multiple Pages)].- [Paper Size] in the step 6 is set to "fit the image."
ForD560/D530
] (COPY/SCAN) to switch to the Scan mode screen.
] or [
] to highlight <Remote Scanner>, and then press [OK].
| [Mail] | The document will be scanned and attached to an e-mail message in your e-mail application. |
| [OCR] | The document will be scanned and read by the OCR software. |
| [Save] | The document will be scanned and saved. |
| [PDF] | The document will be scanned and saved as a PDF file. |
| [Color Scan] [B&W Scan] [Custom 1] [Custom 2] | The document will be scanned and displayed in the registered application. A dialog box appears for each of the buttons. |
